Ga door naar hoofdinhoud
Dell Venue 8 7840 Power and Volume Button Replacement
Wat je nodig hebt
  1. Dell Venue 8 7840 Power and Volume Button Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Power and Volume Button Replacement: stap 2, afbeelding 1 van 1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Power and Volume Button Replacement: stap 3, afbeelding 1 van 1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Power and Volume Button Replacement: stap 4, afbeelding 1 van 1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Power and Volume Button Replacement: stap 5, afbeelding 1 van 1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Power and Volume Button Replacement: stap 6, afbeelding 1 van 1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Power and Volume Button Replacement: stap 7, afbeelding 1 van 1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Power and Volume Button Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the connector from the tablet.
  9. Dell Venue 8 7840 Power and Volume Button Replacement, Battery: stap 9, afbeelding 1 van 1
    • Unscrew the eight 7 mm Philips #1 screws.
    • After the screws are unscrewed, you can take off the silver cover.
  10. Dell Venue 8 7840 Power and Volume Button Replacement: stap 10, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, disconnect the battery from the tablet.
    • After disconnecting the battery, you can remove the battery from the tablet.
  11. Dell Venue 8 7840 Power and Volume Button Replacement, Power and Volume Button: stap 11, afbeelding 1 van 2 Dell Venue 8 7840 Power and Volume Button Replacement, Power and Volume Button: stap 11, afbeelding 2 van 2
    • Using a plastic opening tool, pry open the left side of the tablet.
    • Locate the power and volume buttons.
  12. Dell Venue 8 7840 Power and Volume Button Replacement: stap 12, afbeelding 1 van 1
    • Using a plastic opening tool, push out the volume button from the left side of the tablet.
  13. Dell Venue 8 7840 Power and Volume Button Replacement: stap 13, afbeelding 1 van 1
    Koop
    • Make sure that you hold the left side of the tablet open with a plastic opening tool so that you will be able to take out the volume button.
    • With tweezers, pull out the volume button.
  14. Dell Venue 8 7840 Power and Volume Button Replacement: stap 14, afbeelding 1 van 1
    • With a plastic opening tool, push out the power button from the left side of the tablet.
  15. Dell Venue 8 7840 Power and Volume Button Replacement: stap 15, afbeelding 1 van 1
    • Just like the volume button, you want to make sure that you hold the left side of the tablet open with a plastic opening tool so that you will be able to take out the power button.
    • With tweezers, pull out the power button.
Conclusie
Donnelle January
429 Reputatie
3 handleidingen geschreven
USF Tampa, Team 6-5, Remmell Fall 2016 Lid van USF Tampa, Team 6-5, Remmell Fall 2016
USFT-REMMELL-F16S6G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 768
