Ga door naar hoofdinhoud
Dell Venue 7 Rear Facing Camera Replacement
Wat je nodig hebt
  1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: stap 1, afbeelding 1 van 2 Dell Venue 7 Rear Facing Camera Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Rear Facing Camera Replacement, Battery: stap 2, afbeelding 1 van 1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Rear Facing Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Rear Facing Camera Replacement, Rear Facing Camera: stap 4, afbeelding 1 van 1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Rear Facing Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the camera from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephen Rousseau
663 Reputatie
4 handleidingen geschreven
USF Tampa, Team 11-4, Blackwell Winter 2015 Lid van USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 456
