Ga door naar hoofdinhoud
Dell Venue 7 Battery Replacement
Wat je nodig hebt
  1. Dell Venue 7 Battery Replacement, Rear Case: stap 1, afbeelding 1 van 2 Dell Venue 7 Battery Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Battery Replacement, Battery: stap 2, afbeelding 1 van 1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
Conclusie
chaveza
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 11-4, Blackwell Winter 2015 Lid van USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Leden
10 handleidingen geschreven
4 opmerkingen
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - Antwoord
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 7,368
