Ga door naar hoofdinhoud
Dell VRC100-R Daughterboard Replacement
Wat je nodig hebt
  1. Dell VRC100-R Daughterboard Replacement, Battery: stap 1, afbeelding 1 van 3 Dell VRC100-R Daughterboard Replacement, Battery: stap 1, afbeelding 2 van 3 Dell VRC100-R Daughterboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
  2. Dell VRC100-R Daughterboard Replacement: stap 2, afbeelding 1 van 2 Dell VRC100-R Daughterboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
  3. Dell VRC100-R Daughterboard Replacement, Joystick: stap 3, afbeelding 1 van 3 Dell VRC100-R Daughterboard Replacement, Joystick: stap 3, afbeelding 2 van 3 Dell VRC100-R Daughterboard Replacement, Joystick: stap 3, afbeelding 3 van 3
    • Hold the joystick down with your left thumb to make space for the plastic opening tool.
    • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
    • Slide the plastic opening tool around the perimeter until you can lift the front panel.
    • You may hear a popping noise when you pry off the front panel.
  4. Dell VRC100-R Daughterboard Replacement: stap 4, afbeelding 1 van 2 Dell VRC100-R Daughterboard Replacement: stap 4, afbeelding 2 van 2
    • Grab the joystick and pull away from the controller to remove it.
  5. Dell VRC100-R Daughterboard Replacement, Daughterboard: stap 5, afbeelding 1 van 2 Dell VRC100-R Daughterboard Replacement, Daughterboard: stap 5, afbeelding 2 van 2
    • Remove one 6mm Phillips #0 screw.
  6. Dell VRC100-R Daughterboard Replacement: stap 6, afbeelding 1 van 2 Dell VRC100-R Daughterboard Replacement: stap 6, afbeelding 2 van 2
    • Turn your controller over and orient it so that the thin side is on the top.
    • Remove four 4mm Phillips #0 screws.
  7. Dell VRC100-R Daughterboard Replacement: stap 7, afbeelding 1 van 2 Dell VRC100-R Daughterboard Replacement: stap 7, afbeelding 2 van 2
    • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
    • Push down on the end of the plastic opening tool closest to you to lift the panel up.
    • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
    • You may hear loud popping noises as the back panel separates from the controller.
  8. Dell VRC100-R Daughterboard Replacement: stap 8, afbeelding 1 van 2 Dell VRC100-R Daughterboard Replacement: stap 8, afbeelding 2 van 2
  9. Dell VRC100-R Daughterboard Replacement: stap 9, afbeelding 1 van 3 Dell VRC100-R Daughterboard Replacement: stap 9, afbeelding 2 van 3 Dell VRC100-R Daughterboard Replacement: stap 9, afbeelding 3 van 3
    • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the white locking flap.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the blue cable and pull away from the socket.
    • To reinstall, insert the blue cable into the connector and close the flap on the black line.
  10. Dell VRC100-R Daughterboard Replacement: stap 10, afbeelding 1 van 3 Dell VRC100-R Daughterboard Replacement: stap 10, afbeelding 2 van 3 Dell VRC100-R Daughterboard Replacement: stap 10, afbeelding 3 van 3
    • Use the tip of a spudger or your fingernail to gently flip-up the small white flap holding the orange ribbon cable.
    • Grab the orange cable and pull away from the socket.
    • To reinstall, insert the orange cable into the connector and close the flap on the white line.
  11. Dell VRC100-R Daughterboard Replacement: stap 11, afbeelding 1 van 2 Dell VRC100-R Daughterboard Replacement: stap 11, afbeelding 2 van 2
    • Place two fingers on the perimeter of the daughterboard and lift it away from the controller.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Steven Pineda
881 Reputatie
3 handleidingen geschreven
Cal Poly, Team S18-G3, Livingston Spring 2018 Lid van Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Leden
5 handleidingen geschreven
Één opmerking
Really instructive & easy to follow!
Daisy Chavez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 5,647
