Ga door naar hoofdinhoud
Dell VRC100-R Battery Replacement
  1. Dell VRC100-R Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Dell VRC100-R Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Dell VRC100-R Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
  2. Dell VRC100-R Battery Replacement: stap 2, afbeelding 1 van 2 Dell VRC100-R Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
Conclusie
Kenneth Liu
169 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G3, Livingston Spring 2018 Lid van Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Leden
5 handleidingen geschreven
1Gids Commentaar
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 49
Altijd: 1,097
