Inleiding
This guide will show you how to remove or replace the optical (CD/DVD) drive in a Dell Studio 1737 laptop. This can also be used to recover a disk stuck in the drive.
Wat je nodig hebt
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Unscrew the 8 Phillips head screws marked in the photo.
Use a plastic opening tool to pry the panel away from the laptop body.
Lift the panel up and away.
Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
Remove the 8 8mm ph1 philips head screws (red)
Remove also the one 4mm ph 1 philips head screw (blue)
Unscrew the 2mm ph1 screw located in the first photo
Flip the laptop over and unscrew the 8mm screw located in the second photo
Flip the laptop back over, lift the optical drive up and pull it out
