Ga door naar hoofdinhoud
Dell Studio 1737 Keyboard Replacement
Wat je nodig hebt
  1. Dell Studio 1737 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Studio 1737 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: stap 4, afbeelding 1 van 3 Dell Studio 1737 Keyboard Replacement: stap 4, afbeelding 2 van 3 Dell Studio 1737 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: stap 6, afbeelding 1 van 2 Dell Studio 1737 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: stap 7, afbeelding 1 van 2 Dell Studio 1737 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the ribbon cable as shown
Conclusie
Joseph Jacavone
785 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S8-G4, Catania Spring 2017 Lid van UMass Dartmouth, Team S8-G4, Catania Spring 2017
UMASSD-CATANIA-S17S8G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 719
