Inleiding
You may need to replace your keyboard due to failure. You will need a Phillips 1 screwdriver for this guide.
Wat je nodig hebt
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
