Inleiding
If your screen becomes unresponsive you may need to replace it. A Philips 1 screwdriver and a plastic opening tool are required for this guide.
Wat je nodig hebt
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Insert a plastic opening tool between the bezel and the display cover.
Wiggle it to the release the latches.
Separate the bezel from the cover.
3 andere personen hebben deze handleiding voltooid.
