Inleiding
This guide will show you how to remove the bottom panel, remove the RAM, and replace it properly. It's easier than you think, and takes minimal effort.
Wat je nodig hebt
Gather materials and supplies
Flip laptop over
Remove battery as a safety precaution
Now we'll remove one stick of memory; we'll start with the one on the top (assuming the battery is further away from you)
On each side of the stick you will see two metal tabs
Press these tabs outwards in order to release the RAM
Press these tabs gently. I haven't broken one, but they do look very weak
The slot is spring loaded, and once the tabs are properly opened, it should spring up at an angle
4 andere personen hebben deze handleiding voltooid.
