Ga door naar hoofdinhoud
Dell Studio 1535 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Studio 1535 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 3 van 3
    • Gather tools and materials
    • Flip over laptop, and remove battery as a safety precaution
  2. Dell Studio 1535 Hard Drive Replacement: stap 2, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement: stap 2, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • If you look at the bottom of the laptop, you will notice that there is a panel that is removable
    • Unscrew the screws that hold the panel in place
    • Unscrew the screws until they are loose. They will not come out of the panel
    • After loosening all the screws, lift the panel up from the main chassis
    • You may need to use a flathead screwdriver to lift the panel
  3. Dell Studio 1535 Hard Drive Replacement: stap 3, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement: stap 3, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Now we have access to the internals of the laptop, pretty neat
    • If the battery is away from you, the hard drive should be closer towards you on the left
    • Start by removing the screws holding the caddy into the chassis
    • These screws have a more rounded top, and are longer
    • Once loosened, you can remove with your fingers or tweezers, and then set them aside
  4. Dell Studio 1535 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Now we remove the screws holding the drive to the caddy
    • These screws are have a flatter head, and are shorter
    • These are standard drive screws that are used to mount any hard drive to a mounting device, such as brackets to put it in a desktop computer
    • The manufacturer likes to put these in very tightly, and it may take some effort to remove. I suggest using a screwdriver with a bigger handle, not the one I am using
    • Set these screws aside, apart from the screws we removed in the last step
  5. Dell Studio 1535 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Now that the screws are removed, the caddy can be removed from the chassis and drive
    • Pull the black tab on the right side of the caddy, and pull up
    • It might take some wiggling but it should come out
  6. Dell Studio 1535 Hard Drive Replacement: stap 6, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement: stap 6, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Now that the caddy is removed, we can lift the drive out of it's place
    • It should lift out easily, but it will still be attached with a cable
    • Set it aside on top of the optical drive (the metal surface)
  7. Dell Studio 1535 Hard Drive Replacement: stap 7, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement: stap 7, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement: stap 7, afbeelding 3 van 3
    • Now that the drive is removed, we have to remove the cable connecting it to the motherboard
    • It may be hard to do at first, but there are some groves that you can use to hold on to
    • Pull the connector from the drive gently
    • Wiggling the connector a bit does help a little
  8. Dell Studio 1535 Hard Drive Replacement: stap 8, afbeelding 1 van 3 Dell Studio 1535 Hard Drive Replacement: stap 8, afbeelding 2 van 3 Dell Studio 1535 Hard Drive Replacement: stap 8, afbeelding 3 van 3
    • If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once
    • If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones
    • Pull this tab gently in order to remove the cable
    • Again, wiggling also helps
  9. Dell Studio 1535 Hard Drive Replacement: stap 9, afbeelding 1 van 2 Dell Studio 1535 Hard Drive Replacement: stap 9, afbeelding 2 van 2
    • If you removed the drive using steps 1-7 then what you have should be left in picture 1
    • If you had trouble removing the drive, and you went through to step 8, then the parts remaining will be in picture 2
    • The drive should have a SATA interface, so you should be able to mount it into another computer using 2.5" to 3.5" converter brackets and a SATA cable
Conclusie
12 andere personen hebben deze handleiding voltooid.
Eric Bentley
1.323 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 20,471
