Ga door naar hoofdinhoud
Dell Streak 7 Screen Replacement
Wat je nodig hebt
  1. Dell Streak 7 Screen  Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Screen  Replacement: stap 2, afbeelding 1 van 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Screen  Replacement: stap 3, afbeelding 1 van 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Screen  Replacement: stap 4, afbeelding 1 van 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Screen  Replacement: stap 5, afbeelding 1 van 2 Dell Streak 7 Screen  Replacement: stap 5, afbeelding 2 van 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Screen  Replacement: stap 6, afbeelding 1 van 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Screen  Replacement: stap 7, afbeelding 1 van 2 Dell Streak 7 Screen  Replacement: stap 7, afbeelding 2 van 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Screen  Replacement, Screen: stap 8, afbeelding 1 van 1
    • Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
  9. Dell Streak 7 Screen  Replacement: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, peel off the tape securing the screen to the metal cage around it.
  10. Dell Streak 7 Screen  Replacement: stap 10, afbeelding 1 van 2 Dell Streak 7 Screen  Replacement: stap 10, afbeelding 2 van 2
    • Pull out the ribbon cables through the opening in the metal cage.
    • Lift up the metal cage surrounding the screen by swinging the cage from one side.
  11. Dell Streak 7 Screen  Replacement: stap 11, afbeelding 1 van 1
    • Remove the screen by lifting the screen from the front glass.
Conclusie
Ali Benjelloun
376 Reputatie
3 handleidingen geschreven
USF Tampa, Team 4-6, Passmore Fall 2016 Lid van USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 11
Altijd: 469
