Ga door naar hoofdinhoud
Dell Streak 7 Motherboard Replacement
Wat je nodig hebt
  1. Dell Streak 7 Motherboard Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Motherboard Replacement: stap 5, afbeelding 1 van 2 Dell Streak 7 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Motherboard Replacement: stap 7, afbeelding 1 van 2 Dell Streak 7 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Motherboard Replacement, Headphone Jack: stap 8, afbeelding 1 van 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Motherboard Replacement: stap 9, afbeelding 1 van 2 Dell Streak 7 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Pull the headphone jack up, away from the case.
  10. Dell Streak 7 Motherboard Replacement, GSM Module: stap 10, afbeelding 1 van 2 Dell Streak 7 Motherboard Replacement, GSM Module: stap 10, afbeelding 2 van 2
    • With the spudger, disconnect the antenna cable located on the module.
  11. Dell Streak 7 Motherboard Replacement: stap 11, afbeelding 1 van 2 Dell Streak 7 Motherboard Replacement: stap 11, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, remove the tape connected to the GSM module.
  12. Dell Streak 7 Motherboard Replacement: stap 12, afbeelding 1 van 2 Dell Streak 7 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
  13. Dell Streak 7 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Disconnect the GSM module by lifting the module up, out of the case.
  14. Dell Streak 7 Motherboard Replacement, Motherboard: stap 14, afbeelding 1 van 3 Dell Streak 7 Motherboard Replacement, Motherboard: stap 14, afbeelding 2 van 3 Dell Streak 7 Motherboard Replacement, Motherboard: stap 14, afbeelding 3 van 3
    • Using the spudger, disconnect the front camera by lifting up on the connector.
  15. Dell Streak 7 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Using the Torx screwdriver, remove the six 3mm screws .
  16. Dell Streak 7 Motherboard Replacement: stap 16, afbeelding 1 van 2 Dell Streak 7 Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Lift up the metal cover.
  17. Dell Streak 7 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Use the spudger to lift the vibration motor out of the case.
  18. Dell Streak 7 Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Pull out the motherboard and the battery.
Conclusie
Jair Garcia Varela
301 Reputatie
2 handleidingen geschreven
USF Tampa, Team 4-6, Passmore Fall 2016 Lid van USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Leden
12 handleidingen geschreven
Één opmerking
do you know any website or if you guys even sell the board to him
leonardo_hitman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 11
Altijd: 331
