Ga door naar hoofdinhoud
Dell Streak 7 Headphone Jack Replacement
Wat je nodig hebt
  1. Dell Streak 7 Headphone Jack Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Headphone Jack Replacement: stap 5, afbeelding 1 van 2 Dell Streak 7 Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Headphone Jack Replacement: stap 7, afbeelding 1 van 2 Dell Streak 7 Headphone Jack Replacement: stap 7, afbeelding 2 van 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Headphone Jack Replacement, Headphone Jack: stap 8, afbeelding 1 van 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Headphone Jack Replacement: stap 9, afbeelding 1 van 2 Dell Streak 7 Headphone Jack Replacement: stap 9, afbeelding 2 van 2
    • Pull the headphone jack up, away from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ali Benjelloun
376 Reputatie
3 handleidingen geschreven
USF Tampa, Team 4-6, Passmore Fall 2016 Lid van USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 167
