Inleiding
If your speakers seem to be not in the best condition or broken entirely, use this guide to help change out your speakers. You will need a Phillips #0 screwdriver, a plastic opening tool, and tweezers.
Wat je nodig hebt
Place the device flat on its screen.
Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
Take the segment off and place it to the side.
There are five ribbon cables in a row that must be disconnected.
Using the tweezers, carefully pull out the first cable straight out of the no-fuss ribbon cable connector.
Één andere persoon heeft deze handleiding voltooid.
