Ga door naar hoofdinhoud
Dell Precision T5600 RAM Replacement
  1. Dell Precision T5600 RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Lay the case on its side with the handle side pointing up. Remove the side panel of the computer case by pulling on the handle, as shown in this step.
    • Be sure to use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Dell Precision T5600 RAM Replacement: stap 2, afbeelding 1 van 1
    • Unlock the RAM by pressing down on the tabs on each end of the RAM socket.
    • Once both tabs have been pushed down, gently pull out the existing RAM stick from the motherboard.
  3. Dell Precision T5600 RAM Replacement: stap 3, afbeelding 1 van 2 Dell Precision T5600 RAM Replacement: stap 3, afbeelding 2 van 2
    • Line up the RAM with the groove on the connector line.
    • Do not touch the gold connectors.
  4. Dell Precision T5600 RAM Replacement: stap 4, afbeelding 1 van 2 Dell Precision T5600 RAM Replacement: stap 4, afbeelding 2 van 2
    • Gently insert the RAM into the socket until you feel the tabs from Step 3 click into place.
    • Ensure that both ends of the RAM are secured by their tabs.
  5. Dell Precision T5600 RAM Replacement: stap 5, afbeelding 1 van 1
    • Reattach the side panel from Step 2. Plug your computer back up to the power supply and power on your computer.
    • Once powered on, to verify the installation:
    • Right-click on 'This PC'
    • Left-click on 'Properties'
Conclusie
Fahad Khan
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 24
Altijd: 737
