Ga door naar hoofdinhoud
Dell Precision T3400 Video Card Replacement
  1. Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: stap 1, afbeelding 1 van 2 Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: stap 1, afbeelding 2 van 2
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
  2. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: stap 2, afbeelding 1 van 1
    • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
    • Make sure you ground yourself to prevent static discharge
  3. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: stap 3, afbeelding 1 van 2 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: stap 3, afbeelding 2 van 2
    • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
  4. Dell Precision T3400 Video Card Replacement, Remove the video card: stap 4, afbeelding 1 van 1
    • Hold the card by its top corner and metal bracket and pull it out of its slot.
  5. Dell Precision T3400 Video Card Replacement, Install the new video card: stap 5, afbeelding 1 van 2 Dell Precision T3400 Video Card Replacement, Install the new video card: stap 5, afbeelding 2 van 2
    • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
    • Close the card door and move the blue plastic secure lever back into place.\
    • Ensure that the card you are replacing the existing card with meets wattage and connectivity requirements. Do not force a card into the slot.
Conclusie
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
8 andere personen hebben deze handleiding voltooid.
Josette Cormier
13 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 Leden
14 handleidingen geschreven
1Gids Commentaar
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
Maxime Raguenet - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 51
Altijd: 6,775
