Wat je nodig hebt
Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
Using Phillips screwdriver, remove 2 screws holding case.
Slide case towards back of laptop then lift off to remove.
Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
There is also four more screws holding the drive in place, two at the front of the drive and two at the sides, These will need to be taken out before the drive holder will slide out.
4 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
