Ga door naar hoofdinhoud
Dell Precision M6400 Memory Module Replacement
Wat je nodig hebt
  1. Dell Precision M6400 Memory Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Memory Module Replacement, Base Cover: stap 2, afbeelding 1 van 1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Memory Module Replacement, LED Cover: stap 3, afbeelding 1 van 1
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
  4. Dell Precision M6400 Memory Module Replacement, KeyBoard: stap 4, afbeelding 1 van 1
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
  5. Dell Precision M6400 Memory Module Replacement, Memory Module: stap 5, afbeelding 1 van 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnathan Hammond
45.555 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.994 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 1,465
