Ga door naar hoofdinhoud
Dell Precision M4800 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 1 van 3 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 2 van 3 Dell Precision M4800 Wi-Fi Card Replacement, Wi-Fi Card: stap 1, afbeelding 3 van 3
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the laptop and shut it down.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the laptop.
  2. Dell Precision M4800 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 3 Dell Precision M4800 Wi-Fi Card Replacement: stap 2, afbeelding 2 van 3 Dell Precision M4800 Wi-Fi Card Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the laptop.
    • Lift the base cover and remove it from the laptop.
  3. Dell Precision M4800 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 3 Dell Precision M4800 Wi-Fi Card Replacement: stap 3, afbeelding 2 van 3 Dell Precision M4800 Wi-Fi Card Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the black and white antenna cables by carefully pulling them upwards away from the card, being cautious to not bend the connector.
    • For the antenna pins a simple and slight nudge is usually enough, but remember that these pins are somewhat delicate.
    • Remove the screw.
  4. Dell Precision M4800 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 Dell Precision M4800 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Remove the Wi-Fi card.
  5. Dell Precision M4800 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 2 Dell Precision M4800 Wi-Fi Card Replacement: stap 5, afbeelding 2 van 2
    • Slide the replacement Wi-Fi card into the slot.
    • Tighten the screw securing the Wi-Fi card.
  6. Dell Precision M4800 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 2 Dell Precision M4800 Wi-Fi Card Replacement: stap 6, afbeelding 2 van 2
    • Connect both antenna cables back to the same places according to the color code on the Wi-Fi card.
  7. Dell Precision M4800 Wi-Fi Card Replacement: stap 7, afbeelding 1 van 3 Dell Precision M4800 Wi-Fi Card Replacement: stap 7, afbeelding 2 van 3 Dell Precision M4800 Wi-Fi Card Replacement: stap 7, afbeelding 3 van 3
    • Slide the base cover towards the front of the laptop.
    • Slide the battery back into its place.
    • Make sure to put a little pressure on it if the battery is not fully in place. The battery release latch will automatically click back to the locked position.
Conclusie
Naveen
195 Reputatie
1 Handleiding geschreven
York University, Team B-19, Woodhouse Fall 2023 Lid van York University, Team B-19, Woodhouse Fall 2023
YORK-WOODHOUSE-F23SBG19
2 Leden
1 handleiding geschreven
Één opmerking
Great guide, well-written and concise. Thank you for sharing your knowledge and expertise. Best regards
Loren Martin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 44
Altijd: 380
