Ga door naar hoofdinhoud
Dell Precision M4800 Four Slot RAM Replacement
Wat je nodig hebt
  1. Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: stap 1, afbeelding 1 van 3 Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: stap 1, afbeelding 2 van 3 Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: stap 1, afbeelding 3 van 3
    • Ensure that all electrical sources are removed and turned off.
    • Unplug the charger from the computer.
    • Flip the computer, so the bottom is facing upwards.
    • Slide the release latch to release the battery.
    • Lift and remove the battery from the computer.
  2. Dell Precision M4800 Four Slot RAM Replacement: stap 2, afbeelding 1 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 2, afbeelding 2 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
    • Slide the base cover towards the rear of the computer.
    • Lift the base cover and remove it from the computer,
  3. Dell Precision M4800 Four Slot RAM Replacement: stap 3, afbeelding 1 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 3, afbeelding 2 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 3, afbeelding 3 van 3
    • Pull the retention clips away from the RAM card simultaneously.
    • Lift the RAM card upwards.
    • Pull the first RAM card away from the slot.
    • Repeat this step to remove the second RAM card.
  4. Dell Precision M4800 Four Slot RAM Replacement: stap 4, afbeelding 1 van 2 Dell Precision M4800 Four Slot RAM Replacement: stap 4, afbeelding 2 van 2
    • Insert the replacement RAM card back into the slot diagonally.
    • The RAM card is keyed and will only go into the slot in one orientation.
    • Lightly press the RAM card into the computer.
    • Ensure the RAM card is seated properly. Both tabs should be secured to the RAM card's grooves.
  5. Dell Precision M4800 Four Slot RAM Replacement: stap 5, afbeelding 1 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 5, afbeelding 2 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 5, afbeelding 3 van 3
    • Using a guitar pick or an iFixit Opening Pick, pry a section of the keyboard trim.
    • Gently lift the trim with your finger until multiple tabs of the keyboard trim are unclipped. Go around the trim and unclip all tabs one by one.
    • While lifting the trim you will hear multiple snaps. This is normal as multiple tabs may unclip at once.
    • Once all the tabs are unclipped, remove the keyboard trim from the device.
  6. Dell Precision M4800 Four Slot RAM Replacement: stap 6, afbeelding 1 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 6, afbeelding 2 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 6, afbeelding 3 van 3
    • Using the Phillips #1 screwdriver, remove the three 3 mm screws.
    • Ensure that all the screws are completely removed from the keyboard. They will easily get lost in the computer if they fall out.
    • Lift the keyboard gently from retaining clips.
    • Do not immediately remove the keyboard from the computer. You could damage a connector if you lift it up too quickly or rip it away.
  7. Dell Precision M4800 Four Slot RAM Replacement: stap 7, afbeelding 1 van 2 Dell Precision M4800 Four Slot RAM Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the ribbon connector that attaches the keyboard to the motherboard.
    • Remove the keyboard.
  8. Dell Precision M4800 Four Slot RAM Replacement: stap 8, afbeelding 1 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 8, afbeelding 2 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 8, afbeelding 3 van 3
    • Pull the retention clips away from the first RAM card simultaneously.
    • Lift the first RAM card upwards.
  9. Dell Precision M4800 Four Slot RAM Replacement: stap 9, afbeelding 1 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 9, afbeelding 2 van 3 Dell Precision M4800 Four Slot RAM Replacement: stap 9, afbeelding 3 van 3
    • Pull the retention clips away from the second RAM card simultaneously.
    • Lift the second RAM card upwards.
    • Pull the second RAM card away from the slot.
  10. Dell Precision M4800 Four Slot RAM Replacement: stap 10, afbeelding 1 van 2 Dell Precision M4800 Four Slot RAM Replacement: stap 10, afbeelding 2 van 2
    • Insert the first replacement RAM card into the slot at an angle.
  11. Dell Precision M4800 Four Slot RAM Replacement: stap 11, afbeelding 1 van 2 Dell Precision M4800 Four Slot RAM Replacement: stap 11, afbeelding 2 van 2
    • Insert the second replacement RAM card into the slot at an angle.
    • The RAM card is keyed and will only go into the slot at one orientation.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 88
Altijd: 4,232
