Ga door naar hoofdinhoud
Dell Precision M4600 KeyBoard Replacement
Wat je nodig hebt
  1. Dell Precision M4600 KeyBoard Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Precision M4600 KeyBoard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery release latch into the unlock position.
    • Remove the battery from the system.
  2. Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: stap 2, afbeelding 1 van 3 Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: stap 2, afbeelding 2 van 3 Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: stap 2, afbeelding 3 van 3
    • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
    • Work your way around the sides and bottom edge of the keyboard trim.
    • Lift up to remove the keyboard trim from the unit.
  3. Dell Precision M4600 KeyBoard Replacement, KeyBoard: stap 3, afbeelding 1 van 3 Dell Precision M4600 KeyBoard Replacement, KeyBoard: stap 3, afbeelding 2 van 3 Dell Precision M4600 KeyBoard Replacement, KeyBoard: stap 3, afbeelding 3 van 3
    • Remove the screws securing the keyboard in place.
    • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
    • Disconnect the keyboard data cable from the system board.
  4. Dell Precision M4600 KeyBoard Replacement: stap 4, afbeelding 1 van 3 Dell Precision M4600 KeyBoard Replacement: stap 4, afbeelding 2 van 3 Dell Precision M4600 KeyBoard Replacement: stap 4, afbeelding 3 van 3
    • Remove the keyboard.
    • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
    • Disconnect the keyboard data cable from the back of the keyboard.
  5. Dell Precision M4600 KeyBoard Replacement: stap 5, afbeelding 1 van 1
    • Peel the keyboard data cable away from the keyboard and remove.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnathan Hammond
45.681 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
44 Leden
1.997 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 1,525
