Ga door naar hoofdinhoud
Dell Precision M3800 Touch Pad Replacement
Wat je nodig hebt
  1. Dell Precision M3800 Touch Pad Replacement, Back Cover: stap 1, afbeelding 1 van 2 Dell Precision M3800 Touch Pad Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Touch Pad Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Touch Pad Replacement, Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Touch Pad Replacement, Touch Pad: stap 4, afbeelding 1 van 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: stap 4, afbeelding 2 van 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: stap 4, afbeelding 3 van 3
    • Remove the wire that connects the touch pad with the motherboard with a hooked pry tool (Spudger 3) and by pulling the pull tab to safely remove the wire.
  5. Dell Precision M3800 Touch Pad Replacement: stap 5, afbeelding 1 van 2 Dell Precision M3800 Touch Pad Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two 2mm silver screws.
  6. Dell Precision M3800 Touch Pad Replacement: stap 6, afbeelding 1 van 1
    • Remove the touch pad from the laptop. If needed, use a prying tool to remove the touch pad.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 987
