Ga door naar hoofdinhoud
Dell Precision 7560 Speaker Replacement
Wat je nodig hebt
  1. Dell Precision 7560 Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Precision 7560 Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Precision 7560 Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Speaker Replacement: stap 2, afbeelding 1 van 3 Dell Precision 7560 Speaker Replacement: stap 2, afbeelding 2 van 3 Dell Precision 7560 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Speaker Replacement: stap 3, afbeelding 1 van 3 Dell Precision 7560 Speaker Replacement: stap 3, afbeelding 2 van 3 Dell Precision 7560 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): stap 4, afbeelding 1 van 2 Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): stap 4, afbeelding 2 van 2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Speaker Replacement: stap 5, afbeelding 1 van 2 Dell Precision 7560 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
  6. Dell Precision 7560 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 3 Dell Precision 7560 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 3 Dell Precision 7560 Speaker Replacement, Speaker: stap 6, afbeelding 3 van 3
    • Loosen the eight captive screws that secure the fan assembly using a Phillips #0 screwdriver.
    • Lifting from the bottom, carefully remove the fan.
  7. Dell Precision 7560 Speaker Replacement: stap 7, afbeelding 1 van 3 Dell Precision 7560 Speaker Replacement: stap 7, afbeelding 2 van 3 Dell Precision 7560 Speaker Replacement: stap 7, afbeelding 3 van 3
    • Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Remove the metal overlay.
    • Disconnect the wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card.
  8. Dell Precision 7560 Speaker Replacement: stap 8, afbeelding 1 van 2 Dell Precision 7560 Speaker Replacement: stap 8, afbeelding 2 van 2
    • Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
    • Remove, carefully and completely, any wires running over the frame.
    • Lift the metal frame.
  9. Dell Precision 7560 Speaker Replacement: stap 9, afbeelding 1 van 2 Dell Precision 7560 Speaker Replacement: stap 9, afbeelding 2 van 2
    • Flip up the metal edge holding down the SD connection.
    • Gently pull to disconnect the metal connecting wire.
  10. Dell Precision 7560 Speaker Replacement: stap 10, afbeelding 1 van 3 Dell Precision 7560 Speaker Replacement: stap 10, afbeelding 2 van 3 Dell Precision 7560 Speaker Replacement: stap 10, afbeelding 3 van 3
    • Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
    • Remove the metal cap.
    • Disconnect the wire bundle.
  11. Dell Precision 7560 Speaker Replacement: stap 11, afbeelding 1 van 3 Dell Precision 7560 Speaker Replacement: stap 11, afbeelding 2 van 3 Dell Precision 7560 Speaker Replacement: stap 11, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
    • Carefully remove the speaker wire from the motherboard.
  12. Dell Precision 7560 Speaker Replacement: stap 12, afbeelding 1 van 2 Dell Precision 7560 Speaker Replacement: stap 12, afbeelding 2 van 2
    • Using both hands, carefully lift and remove the speaker.
Conclusie
Neevia Vinod
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 71
