Inleiding
This guide covers how to replace the solid-state drive (SSD) on a Dell Precision 7560 laptop. The SSD is responsible for storing data from your device permanently in memory. Before continuing to the guide, please make sure that the device's battery is removed. Please refer to our Dell Precision 7560 Battery replacement guide. This will prevent data from being lost and will prevent the risk of circuit fires.
Wat je nodig hebt
Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
Remove the back cover by lifting at the corners.
Unscrew and remove the two 3 mm screws that secure the solid-state drive.
