Ga door naar hoofdinhoud
Dell Precision 7560 Solid-State Drive (SSD) Replacement
Wat je nodig hebt
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: stap 1, afbeelding 3 van 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 2, afbeelding 1 van 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 2, afbeelding 2 van 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 2, afbeelding 3 van 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 3, afbeelding 1 van 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 3, afbeelding 2 van 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 3, afbeelding 3 van 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): stap 4, afbeelding 1 van 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): stap 4, afbeelding 2 van 2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 5, afbeelding 1 van 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: stap 5, afbeelding 2 van 2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
Conclusie
Hector
249 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 47
Altijd: 490
