Ga door naar hoofdinhoud
Dell Precision 7560 Screen Replacement
Wat je nodig hebt
  1. Dell Precision 7560 Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Dell Precision 7560 Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Dell Precision 7560 Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: stap 2, afbeelding 1 van 2 Dell Precision 7560 Screen Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: stap 3, afbeelding 1 van 3 Dell Precision 7560 Screen Replacement: stap 3, afbeelding 2 van 3 Dell Precision 7560 Screen Replacement: stap 3, afbeelding 3 van 3
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Conclusie
Laisha
202 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 63
Altijd: 638
