Ga door naar hoofdinhoud
Dell Precision 7560 Keyboard Replacement
Wat je nodig hebt
  1. Dell Precision 7560 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Precision 7560 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Precision 7560 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: stap 2, afbeelding 1 van 3 Dell Precision 7560 Keyboard Replacement: stap 2, afbeelding 2 van 3 Dell Precision 7560 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: stap 3, afbeelding 1 van 3 Dell Precision 7560 Keyboard Replacement: stap 3, afbeelding 2 van 3 Dell Precision 7560 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 3 Dell Precision 7560 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 3 Dell Precision 7560 Keyboard Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: stap 5, afbeelding 1 van 3 Dell Precision 7560 Keyboard Replacement: stap 5, afbeelding 2 van 3 Dell Precision 7560 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: stap 6, afbeelding 1 van 3 Dell Precision 7560 Keyboard Replacement: stap 6, afbeelding 2 van 3 Dell Precision 7560 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
Conclusie
Jack Allred
336 Reputatie
2 handleidingen geschreven
Één opmerking
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 56
Altijd: 738
