Ga door naar hoofdinhoud
Dell Precision 7510 Memory Module Replacement
Wat je nodig hebt
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: stap 1, afbeelding 1 van 1
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: stap 2, afbeelding 1 van 1
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: stap 3, afbeelding 1 van 1
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: stap 5, afbeelding 1 van 1
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: stap 6, afbeelding 1 van 1
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: stap 7, afbeelding 1 van 1
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: stap 8, afbeelding 1 van 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
Eindstreep
Johnathan Hammond
45.540 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
43 Leden
1.993 handleidingen geschreven
1Gids Commentaar
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 51
Altijd: 11,490
