Inleiding
This guide shows how to remove and replace the battery for the Dell Precision 5520 laptop.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
Pry the edges of the base cover and lift it to remove it from the computer.
Disconnect the battery cable from the system board [1].
Remove the seven M2x4 screws that secure the battery to the computer [2].
Lift the battery off the computer [3].
Will the BIOS complain that this is not a Dell purchased battery and thus refuse to charge it?
9 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Great directions. Simple, yet precise. Took less than five minutes.
Easy peasy. Great instruction, exact parts with exact tools. Great price. Thanks IFIXIT!
Dell official maintenance guide is available at: https://dl.dell.com/topicspdf/precision-...
The base base cover removal is documented in section 'Disassembly and reassembly'.
Raphaël Bleuse - Antwoord
