Ga door naar hoofdinhoud
Dell Precision 5510 RAM Replacement
Wat je nodig hebt
  1. Dell Precision 5510 RAM Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 RAM Replacement: stap 2, afbeelding 1 van 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 RAM Replacement, RAM: stap 3, afbeelding 1 van 2 Dell Precision 5510 RAM Replacement, RAM: stap 3, afbeelding 2 van 2
    • Chose which RAM board you will be replacing on the motherboard.
    • There are two next to each other. One is outlined here.
  4. Dell Precision 5510 RAM Replacement: stap 4, afbeelding 1 van 1
    • Place fingers on black plastic tabs.
    • Bend the tabs slightly away from the RAM board until the RAM board springs upward.
  5. Dell Precision 5510 RAM Replacement: stap 5, afbeelding 1 van 1
    • Once the RAM board springs up to an elevated angle as pictured here, gently grab the board.
    • Pull the board (in the direction shown) out of its slot where it is still inserted .
  6. Dell Precision 5510 RAM Replacement: stap 6, afbeelding 1 van 1
    • If replacing both RAM boards, follow the same process for removal of the other RAM board.
    • The other board is directly to the right of the prior pictured one, and identical. Both are outlined in this picture.
Conclusie
Cooper Zuranski
109 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-1, Harley Spring 2022 Lid van IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Leden
4 handleidingen geschreven
1Gids Commentaar
T4 Torx is listed under required tools, but T5 is the correct size for my 5510.
Chris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 22
Altijd: 735
