Ga door naar hoofdinhoud
Dell Photo Printer 540 Cooling Fan Replacement
Wat je nodig hebt
  1. Dell Photo Printer 540 Cooling Fan Replacement, Case: stap 1, afbeelding 1 van 1
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 Cooling Fan Replacement: stap 4, afbeelding 1 van 1
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 Cooling Fan Replacement: stap 5, afbeelding 1 van 1
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 Cooling Fan Replacement: stap 6, afbeelding 1 van 2 Dell Photo Printer 540 Cooling Fan Replacement: stap 6, afbeelding 2 van 2
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
  7. Dell Photo Printer 540 Cooling Fan Replacement, Cooling Fan: stap 7, afbeelding 1 van 1
    • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
  8. Dell Photo Printer 540 Cooling Fan Replacement: stap 8, afbeelding 1 van 1
    • Locate the red and black cable that is connecting the fan to the top of the logic board.
  9. Dell Photo Printer 540 Cooling Fan Replacement: stap 9, afbeelding 1 van 1
    • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alena Raymond
25 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-7, Forte Spring 2012 Lid van Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 578
