Ga door naar hoofdinhoud
Inleiding
Prerequisite Only
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  5. Remove the rubber grommets from the base of the fan. A spudger may be useful. Remove the rubber grommets from the base of the fan. A spudger may be useful.
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
  6. Press on the blue release tab and pull the upper fan out of the computer. Press on the blue release tab and pull the upper fan out of the computer.
    • Press on the blue release tab and pull the upper fan out of the computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Wyatt
742 Reputatie
6 handleidingen geschreven
Cal Poly, Team 22-4, Maness Fall 2010 Lid van Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Leden
26 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 1,849
