Ga door naar hoofdinhoud
Dell Optiplex SX280 Upper Fan Replacement
Wat je nodig hebt
  1. Dell Optiplex SX280 Upper Fan Replacement, Panel Cover: stap 1, afbeelding 1 van 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Upper Fan Replacement: stap 2, afbeelding 1 van 2 Dell Optiplex SX280 Upper Fan Replacement: stap 2, afbeelding 2 van 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Upper Fan Replacement: stap 3, afbeelding 1 van 2 Dell Optiplex SX280 Upper Fan Replacement: stap 3, afbeelding 2 van 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: stap 4, afbeelding 1 van 2 Dell Optiplex SX280 Upper Fan Replacement, Upper Fan: stap 4, afbeelding 2 van 2
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Upper Fan Replacement: stap 5, afbeelding 1 van 2 Dell Optiplex SX280 Upper Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  6. Dell Optiplex SX280 Upper Fan Replacement: stap 6, afbeelding 1 van 2 Dell Optiplex SX280 Upper Fan Replacement: stap 6, afbeelding 2 van 2
    • Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
  7. Dell Optiplex SX280 Upper Fan Replacement: stap 7, afbeelding 1 van 1
    • Pull the upper fan out of the computer.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Tom
850 Reputatie
7 handleidingen geschreven
Cal Poly, Team 22-4, Maness Fall 2010 Lid van Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 17
Altijd: 5,310
