Ga door naar hoofdinhoud
Dell Optiplex SX280 Heat Sink Replacement
  1. Dell Optiplex SX280 Heat Sink Replacement, Panel Cover: stap 1, afbeelding 1 van 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Heat Sink Replacement: stap 2, afbeelding 1 van 2 Dell Optiplex SX280 Heat Sink Replacement: stap 2, afbeelding 2 van 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Heat Sink Replacement: stap 3, afbeelding 1 van 2 Dell Optiplex SX280 Heat Sink Replacement: stap 3, afbeelding 2 van 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: stap 4, afbeelding 1 van 2 Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: stap 4, afbeelding 2 van 2
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  5. Dell Optiplex SX280 Heat Sink Replacement: stap 5, afbeelding 1 van 2 Dell Optiplex SX280 Heat Sink Replacement: stap 5, afbeelding 2 van 2
    • Press down on the release tab above the heat sink.
  6. Dell Optiplex SX280 Heat Sink Replacement: stap 6, afbeelding 1 van 2 Dell Optiplex SX280 Heat Sink Replacement: stap 6, afbeelding 2 van 2
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
Conclusie
4 andere personen hebben deze handleiding voltooid.
Tom
850 Reputatie
7 handleidingen geschreven
Cal Poly, Team 22-4, Maness Fall 2010 Lid van Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Leden
26 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 6,283
