Ga door naar hoofdinhoud
Dell Optiplex SX280 Battery Replacement
Wat je nodig hebt
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: stap 1, afbeelding 1 van 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: stap 2, afbeelding 1 van 2 Dell Optiplex SX280 Battery Replacement: stap 2, afbeelding 2 van 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: stap 3, afbeelding 1 van 2 Dell Optiplex SX280 Battery Replacement: stap 3, afbeelding 2 van 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: stap 4, afbeelding 1 van 2 Dell Optiplex SX280 Battery Replacement, Hard Drive: stap 4, afbeelding 2 van 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: stap 5, afbeelding 1 van 2 Dell Optiplex SX280 Battery Replacement: stap 5, afbeelding 2 van 2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: stap 6, afbeelding 1 van 1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: stap 7, afbeelding 1 van 2 Dell Optiplex SX280 Battery Replacement: stap 7, afbeelding 2 van 2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: stap 8, afbeelding 1 van 1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: stap 9, afbeelding 1 van 1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: stap 10, afbeelding 1 van 3 Dell Optiplex SX280 Battery Replacement: stap 10, afbeelding 2 van 3 Dell Optiplex SX280 Battery Replacement: stap 10, afbeelding 3 van 3
    • Upon replacement, simply push the battery into the motherboard.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Tom
850 Reputatie
7 handleidingen geschreven
Cal Poly, Team 22-4, Maness Fall 2010 Lid van Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Leden
26 handleidingen geschreven
Één opmerking
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 21
Altijd: 11,913
