Inleiding
You should never try to repair a power supply unit. These are appropriately labeled, "Field Replaceable Units" for a reason. Disassembling a computer power supply unit can seriously harm and even kill you.
Wat je nodig hebt
Power down your PC and remove the power cord from the back.
With the computer standing upright, firmly pull on the tab at the back of the computer.
When the side panel pops free, gently pull the panel away from the computer.
Gently disconnect the power cables from the motherboard and drives.
Remove the four screws that attach the power supply on the back of the chassis.
Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
10 andere personen hebben deze handleiding voltooid.
