Ga door naar hoofdinhoud
Dell Optiplex GX620 Front panel Replacement
Wat je nodig hebt
  1. Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: stap 1, afbeelding 1 van 2 Dell Optiplex GX620 Front panel Replacement, How to unplug and discharge before repair: stap 1, afbeelding 2 van 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Front panel Replacement: stap 2, afbeelding 1 van 2 Dell Optiplex GX620 Front panel Replacement: stap 2, afbeelding 2 van 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Front panel Replacement, Dell Optiplex GX620 Side Panel Disassembly: stap 3, afbeelding 1 van 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: stap 4, afbeelding 1 van 3 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: stap 4, afbeelding 2 van 3 Dell Optiplex GX620 Front panel Replacement, Unplug your hard drive.: stap 4, afbeelding 3 van 3
    • Remove the SATA power and data cables.
    • SATA Power
    • SATA Data
  5. Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: stap 5, afbeelding 1 van 3 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: stap 5, afbeelding 2 van 3 Dell Optiplex GX620 Front panel Replacement, Unplug your floppy drive.: stap 5, afbeelding 3 van 3
    • Unplug the power and data cables.
  6. Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: stap 6, afbeelding 1 van 2 Dell Optiplex GX620 Front panel Replacement, Unplug the fan.: stap 6, afbeelding 2 van 2
    • Unplug the fan.
  7. Dell Optiplex GX620 Front panel Replacement: stap 7, afbeelding 1 van 2 Dell Optiplex GX620 Front panel Replacement: stap 7, afbeelding 2 van 2
    • Remove the two Phillips #2 screws.
  8. Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: stap 8, afbeelding 1 van 3 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: stap 8, afbeelding 2 van 3 Dell Optiplex GX620 Front panel Replacement, Remove the heat sink.: stap 8, afbeelding 3 van 3
    • Pull the heat sink up.
  9. Dell Optiplex GX620 Front panel Replacement: stap 9, afbeelding 1 van 3 Dell Optiplex GX620 Front panel Replacement: stap 9, afbeelding 2 van 3 Dell Optiplex GX620 Front panel Replacement: stap 9, afbeelding 3 van 3
    • Pull the two tabs and pull it out.
    • This needs a lot of force to take it off.
  10. Dell Optiplex GX620 Front panel Replacement, Remove front panel: stap 10, afbeelding 1 van 2 Dell Optiplex GX620 Front panel Replacement, Remove front panel: stap 10, afbeelding 2 van 2
    • Remove the one Phillips #2.
    • Remove the Data cable.
    • Taking this cable off will brake some of the plastic thats locking it in. But you can still plug the cable back in.
  11. Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: stap 11, afbeelding 1 van 2 Dell Optiplex GX620 Front panel Replacement, Remove the last screw.: stap 11, afbeelding 2 van 2
    • Remove the one Phillips #2 screw.
    • Now you can replace it with a new one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Padraic Hoselton
4.180 Reputatie
12 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.542 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 34
Altijd: 1,513
