Ga door naar hoofdinhoud
Dell Optiplex GX620 CMOS Battery Replacement
Wat je nodig hebt
  1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: stap 1, afbeelding 1 van 2 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: stap 1, afbeelding 2 van 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CMOS Battery Replacement: stap 2, afbeelding 1 van 2 Dell Optiplex GX620 CMOS Battery Replacement: stap 2, afbeelding 2 van 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: stap 3, afbeelding 1 van 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: stap 4, afbeelding 1 van 1
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
Conclusie
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
7 andere personen hebben deze handleiding voltooid.
Kristina
198 Reputatie
7 handleidingen geschreven
Pasco Hernando, Team 5-1, Prince Fall 2014 Lid van Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Leden
15 handleidingen geschreven
2 opmerkingen
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - Antwoord
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 54
Altijd: 15,504
