Ga door naar hoofdinhoud
Dell Optiplex 745 Ultra Small Form Factor CPU Replacement
Wat je nodig hebt
  1. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 2, afbeelding 1 van 1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 3, afbeelding 1 van 1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
  4. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: stap 4, afbeelding 1 van 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU Heat Sink: stap 4, afbeelding 2 van 2
    • Remove the blue shield by sliding it straight upwards.
  5. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 5, afbeelding 1 van 3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 5, afbeelding 2 van 3 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 5, afbeelding 3 van 3
    • Pull back on the tab nearest to the front case fan.
    • Slide the CPU heat sink from under the clip and pull upward.
    • You may need to twist the CPU heat sink side to side to free it from the thermal paste.
  6. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: stap 6, afbeelding 1 van 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement, CPU: stap 6, afbeelding 2 van 2
    • Ground yourself before removing any internal components.
    • Push release lever down slightly and away from CPU.
  7. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 7, afbeelding 1 van 2 Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 7, afbeelding 2 van 2
    • Lift and rotate processor cover off of CPU.
    • Processor cover will remain attached.
  8. Dell Optiplex 745 Ultra Small Form Factor CPU Replacement: stap 8, afbeelding 1 van 1
    • Using two fingers holding the sides, lift the CPU from the socket.
    • Do not touch the underside of the CPU or any of the pins.
    • When replacing the CPU, do not use excessive force.
    • Ensure to use the alignment-notches on the new CPU, when replacing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
donnavon
707 Reputatie
7 handleidingen geschreven
Pasco Hernando, Team 1-1, Prince Fall 2014 Lid van Pasco Hernando, Team 1-1, Prince Fall 2014
PHSC-PRINCE-F14S1G1
11 Leden
14 handleidingen geschreven
Één opmerking
What Cpu does it use?
Jazelle Estrada - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 2,185
