Ga door naar hoofdinhoud
Dell OptiPlex GX260 RAM Replacement
  1. Dell OptiPlex GX260 RAM Replacement, Case: stap 1, afbeelding 1 van 2 Dell OptiPlex GX260 RAM Replacement, Case: stap 1, afbeelding 2 van 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    cool de faires des sites comme ca :)
    baptiste Prando - Antwoord
    Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
    sheila_jones - Antwoord
    I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
    Elvis 1357 - Antwoord
    Also, want to add another HD....but, there are no cables at all?
  2. Dell OptiPlex GX260 RAM Replacement, RAM: stap 2, afbeelding 1 van 2 Dell OptiPlex GX260 RAM Replacement, RAM: stap 2, afbeelding 2 van 2
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
    tg beaufion travail
    Heinsenberg - Antwoord
    Albert reste polie
    jvai tenculer baltringue va
    Oh calmer vous les collégiens la!
    Momo - Antwoord
    zamaaaaaaaaan tu fait quoi la
    sisoko kirikou - Antwoord
    coco arrete tes blocus
    Coco tete du blocus -
    BENJUX ENTHE FLUX arret t’es conérie
    Sdk mes bébé la
    LaMereACoco - Antwoord
    c’est un ouff l’acteur
    Coco tete du blocus - Antwoord
    c’est un oufff Ritchie
    Abder.zamouk - Antwoord
Conclusie
11 andere personen hebben deze handleiding voltooid.
Kevin Schapansky
1.457 Reputatie
9 handleidingen geschreven
Cal Poly, Team 4-48, Amido Fall 2010 Lid van Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Leden
27 handleidingen geschreven
5 opmerkingen
lol mdr hihi
antouibne - Antwoord
Rideau Cottage est construit par Stewart Taylor and Co., selon les plans de l'architecte ++Frederick Preston Rubidge++ ; le chantier commence en 1866 et se termine l'année suivante^^++[2]. Le coût de la construction s'est élevé à 5 000 ++$CA++^^++[1++]. Bien qu'il ait été prévu dans les premiers temps pour servir de résidence au ++secrétaire du gouverneur général++, le cottage est aussi utilisé par la suite comme résidence officielle pour les dignitaires en visite^^++[3^^].
Le premier agrandissement de Rideau Cottage a lieu en 1872 avec l'ajout d'un second étage et d'une ++véranda++ selon les plans de ++Thomas Seaton Scott++, architecte en chef de ++Travaux publics Canada++. En 1905, une annexe est ajoutée à l'arrière, principalement pour agrandir la cuisine. En 1933, une aile de deux étages est ajoutée au côté nord dans le but d'agrandir la salle à manger. Un porche grillagé et un garage contigu sont ajoutés par la suite. En 1954-1955 la véranda est remplacée par un ++porche++ d'inspiration classique^^++[2++^^].
Astier RPZ hein
Momo - Antwoord
vachement bien ♥
Scooby-Doo - Antwoord
victime du 95
moufasa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 10,707
