Wat je nodig hebt
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Locate the power supply in the case.
Disconnect the AXT power cable to the motherboard.
Disconnect the P4 12 volt power cable from the motherboard.
Disconnect the power cable from the optical drive.
Disconnect the floppy drive power cable.
Disconnect the hard drive power cable.
6 andere personen hebben deze handleiding voltooid.
cool de faires des sites comme ca :)
baptiste Prando - Antwoord
Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
sheila_jones - Antwoord
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Elvis 1357 - Antwoord
Also, want to add another HD....but, there are no cables at all?
