Ga door naar hoofdinhoud
Dell OptiPlex GX260 Optical Drive Replacement
  1. Dell OptiPlex GX260 Optical Drive Replacement, Case: stap 1, afbeelding 1 van 2 Dell OptiPlex GX260 Optical Drive Replacement, Case: stap 1, afbeelding 2 van 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    Vraag FixBot
  2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: stap 2, afbeelding 1 van 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: stap 2, afbeelding 2 van 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: stap 2, afbeelding 3 van 3
    • Identify the optical drive in the case.
    • Remove the analog audio cable from the optical drive.
    • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
    • Remove the power cable from the optical drive.
    Vraag FixBot
  3. Dell OptiPlex GX260 Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Push the two green tabs toward each other to release the optical drive and lift it out.
    Vraag FixBot
Conclusie
5 andere personen hebben deze handleiding voltooid.
Kevin Schapansky
1.478 Reputatie
9 handleidingen geschreven
Cal Poly, Team 4-48, Amido Fall 2010 Lid van Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Leden
27 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 80
Altijd: 9,340
