Ga door naar hoofdinhoud
Dell OptiPlex GX260 Motherboard Replacement
Wat je nodig hebt
  1. Dell OptiPlex GX260 Motherboard Replacement, Case: stap 1, afbeelding 1 van 2 Dell OptiPlex GX260 Motherboard Replacement, Case: stap 1, afbeelding 2 van 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Motherboard Replacement, Main Fan: stap 2, afbeelding 1 van 2 Dell OptiPlex GX260 Motherboard Replacement, Main Fan: stap 2, afbeelding 2 van 2
    • Disconnect the fan cable from the motherboard.
  3. Dell OptiPlex GX260 Motherboard Replacement: stap 3, afbeelding 1 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 3, afbeelding 2 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
  4. Dell OptiPlex GX260 Motherboard Replacement, RAM: stap 4, afbeelding 1 van 2 Dell OptiPlex GX260 Motherboard Replacement, RAM: stap 4, afbeelding 2 van 2
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
  5. Dell OptiPlex GX260 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Dell OptiPlex GX260 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Disconnect the ATX power cable to the motherboard.
    • Disconnect the P4 12V(4x2) power cable from the motherboard.
  6. Dell OptiPlex GX260 Motherboard Replacement: stap 6, afbeelding 1 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 6, afbeelding 2 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the front panel ribbon cable by gently pulling it straight up.
    • Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
    • Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
  7. Dell OptiPlex GX260 Motherboard Replacement: stap 7, afbeelding 1 van 2 Dell OptiPlex GX260 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard.
    • Disconnect the optical drive audio cable connector from the motherboard.
    • Disconnect the audio input/output cable from the motherboard.
  8. Dell OptiPlex GX260 Motherboard Replacement: stap 8, afbeelding 1 van 2 Dell OptiPlex GX260 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Lift the metal tab near the right corner of the motherboard.
    • Pull the green tab toward the front of the PC to release the motherboard.
    • From the rear of the PC, push the ports in while lifting the motherboard up and flipping it away from you.
  9. Dell OptiPlex GX260 Motherboard Replacement: stap 9, afbeelding 1 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 9, afbeelding 2 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Stand the motherboard up as shown.
    • Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
  10. Dell OptiPlex GX260 Motherboard Replacement: stap 10, afbeelding 1 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 10, afbeelding 2 van 3 Dell OptiPlex GX260 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Remove the screw at the rear of the motherboard.
    • Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base.
    • If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
Conclusie
15 andere personen hebben deze handleiding voltooid.
Kevin Schapansky
1.457 Reputatie
9 handleidingen geschreven
Cal Poly, Team 4-48, Amido Fall 2010 Lid van Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Leden
27 handleidingen geschreven
4 opmerkingen
Mines stuck for some reason I almost bent the frame from pushing the ports in while lifting and pulling the tray tab away
james dee - Antwoord
make sure you doing it the correct side!
Robert Stokes-Barnett -
muy bueno gracias bro
Tony Fernandez - Antwoord
Mine did not have the big green fan in back. Rest of the disassembly was similar, until I got to actually removing the PCB from the metal back plate. This says to simply slide it forward while holding the plate in place. Yeah… well, in theory. It actually took a fair amount of gentle prying to get the PCB to slide forward. The key is the little metal grounding clips in the corners. The fingers do not actually present much pressure. However, the vertical metal to which they press is an overhang. So the trick is to gently FORCE the PCB forward at each rear corner until such time as the overhang no longer exists. At this point the vertical metal tab will be full back against their respective slots. The PCB will simply lift out then.
jknox - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 70
Altijd: 38,610
