Ga door naar hoofdinhoud
Dell OptiPlex GX260 Hard Drive Replacement
Wat je nodig hebt
  1. Dell OptiPlex GX260 Hard Drive Replacement, Case: stap 1, afbeelding 1 van 2 Dell OptiPlex GX260 Hard Drive Replacement, Case: stap 1, afbeelding 2 van 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 2 van 3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: stap 2, afbeelding 3 van 3
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
  3. Dell OptiPlex GX260 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Kevin Schapansky
1.457 Reputatie
9 handleidingen geschreven
Cal Poly, Team 4-48, Amido Fall 2010 Lid van Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Leden
27 handleidingen geschreven
Één opmerking
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 18,428
