Ga door naar hoofdinhoud
Dell OptiPlex FX170 RAM Replacement
Wat je nodig hebt
  1. Dell OptiPlex FX170 RAM  Replacement, Case: stap 1, afbeelding 1 van 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 RAM  Replacement: stap 2, afbeelding 1 van 2 Dell OptiPlex FX170 RAM  Replacement: stap 2, afbeelding 2 van 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 RAM  Replacement: stap 3, afbeelding 1 van 3 Dell OptiPlex FX170 RAM  Replacement: stap 3, afbeelding 2 van 3 Dell OptiPlex FX170 RAM  Replacement: stap 3, afbeelding 3 van 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 RAM  Replacement: stap 4, afbeelding 1 van 2 Dell OptiPlex FX170 RAM  Replacement: stap 4, afbeelding 2 van 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 RAM  Replacement, RAM: stap 5, afbeelding 1 van 2 Dell OptiPlex FX170 RAM  Replacement, RAM: stap 5, afbeelding 2 van 2
    • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
  6. Dell OptiPlex FX170 RAM  Replacement: stap 6, afbeelding 1 van 1
    • Lift and pull out the RAM.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 47
Altijd: 1,589
