Ga door naar hoofdinhoud
Dell Netbook e6400 Tastiera Replacement
Wat je nodig hebt
  1. Dell Netbook e6400 Tastiera Replacement, Tastiera: stap 1, afbeelding 1 van 1
    • Rimuovere batteria
  2. Dell Netbook e6400 Tastiera Replacement: stap 2, afbeelding 1 van 2 Dell Netbook e6400 Tastiera Replacement: stap 2, afbeelding 2 van 2
    • Estrarre la card dalle slot tirando la linguetta
    • Facendo leva sugli agganci in plastica si sgancia nella parte anteriore la linea di tasti in alto che danno accesso alle viti fissaggio tastiera
  3. Dell Netbook e6400 Tastiera Replacement: stap 3, afbeelding 1 van 1
    • Fare leva sotto per estrarre la linea di tasti superiore
  4. Dell Netbook e6400 Tastiera Replacement: stap 4, afbeelding 1 van 3 Dell Netbook e6400 Tastiera Replacement: stap 4, afbeelding 2 van 3 Dell Netbook e6400 Tastiera Replacement: stap 4, afbeelding 3 van 3
    • Svitare le due viti a croce che tengono la tastiera fissata al corpo notebook
    • Nuova riga.itilizzare la linguetta nera per tirare indietro e verso l'altro per sganciare la tastiera
Conclusie
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
8 andere personen hebben deze handleiding voltooid.
Smilzo
11.276 Reputatie
39 handleidingen geschreven
2 opmerkingen
ciao and thanks for this guide @smilzo !
I recently had to re-seat the keyboard, which is a common trick for old Dell laptops when the keyboards starts having issues and types nonsense. However after putting it back together, the keyboard doesn’t light up anymore. what am I doing wrong? did I miss a connector?
alfx - Antwoord
hi, sorry for what happened, try to disassemble the keyboard again and check that the connectors are inserted well on the correct side and that the cable has not broken.  good luck
Smilzo -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 24
Altijd: 1,565
