Ga door naar hoofdinhoud
Dell Latitude X300 Screen Replacement
Wat je nodig hebt
  1. Dell Latitude X300 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure the Dell Latitude X300 power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Screen Replacement: stap 2, afbeelding 1 van 2 Dell Latitude X300 Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Screen Replacement: stap 3, afbeelding 1 van 1
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so extreme care is required.
  4. Dell Latitude X300 Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
  5. Dell Latitude X300 Screen Replacement: stap 5, afbeelding 1 van 2 Dell Latitude X300 Screen Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the screen and place it on it's face.
    • Disconnect the wiring attached to the screen.
    • It is important not to damage this wire.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jacob
9 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 703
