Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the laptop over so that the bottom is facing up.
Remove the two #0 3 mm screws holding the cover plate.
Push both metal retaining clips outward at the same time using your hands carefully.
Gently pull the memory out of the retainer at the same 45 degree angle.
Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
