Ga door naar hoofdinhoud
Dell Latitude X300 Keyboard Replacement
Wat je nodig hebt
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  2. Dell Latitude X300 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Latitude X300 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
Conclusie
Jacob Egorov
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-20, Maness Winter 2012 Lid van Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,255
